Lubricate Door Hinges
Used to be a CLK430
Hello W211 owners! I'm searching for a DIY on what and how to lubricate the door hinges on a 2007 W211. Any ideas? Thanks in advance!!
2005 E320 CDI
![Wink](https://mbworld.org/forums/images/icons/icon12.gif)
Hi nicky,
It should come with one of those (usually) red tubes one inserts into the spray nozzle to direct the spray without getting it everywhere.
This product will penetrate the pin area of the hinge to lubricate, and will set up as a waxy coating after a few minutes...
...so as not to attract dirt and leave a mess.
This product was developed by the Boeing (Aircraft) Co. to provide a means of protecting aluminum riveted seams. It works equally well on ferrous (iron, steel) metals as well, and due to the capillary action is well-suited for applications like hinges.
Good for saltwater applications (moving metal parts) as well, due to it's resistance to washing off.
No, I don't have any stock in the Co. that makes it...
...You asked for a recommendation, so here is mine.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Best wishes,
Mike
Best wishes,
Mike
Funny, I would have suggested white Lithium grease spray, which I use on mine.
However, this Boeshield product looks really interesting. Great tip !
T-9's Boeshield
T-9 Boeshield is a wax dissolved in solvents with corrosion inhibitors added. It is used by woodworkers to keep iron and steel surfaces slippery and rust-protected and by bicylists to lubricate their chains and to make them water-proof.
I am not so sure it would make a good hinge lubricant. I think you want a grease for that kind of application, not a wax.
Worth a try, though, I suppose. Although it is pricey compared to white lithium grease spray. Like $10 a can vs. about $2.
- nopcbs
- nopcbs
