ABS and ESP light on after replaced rear hub
My abs and esp lights came on after i had a shot replace the rear hub, hooked it to the scaner and said it was low voltage so i figure its the battery? but even after driving it for a day still on! goes off for a few sec after i start my car but then comes back on again, any ideas? thanks!
Alex M
Alex M
Alex;
you may have found an answer by now, but the shop or you may have to pull the hub off. if any dirt or grease got on the exterior of the grease seal (tone ring), your sensor will not read the speed of the hub, it has to be hosptial clean on the seal exterior and spindle around the sensor.
