E-Class (W211) 2003-2009
Check engine light on.. unable to read codes
Old Jan 21, 2011 | 06:55 PM
SterlingG's Avatar
2003 e500
MY check engine light came on today, and the engine started to misfire. I tried to use a generic odb2 reader and it showed an error communicating. So then I plugged in my SNAP-ON MTG-2500 with the proper mercedes modules and it was unable to connect to the engine ecu. I was able to run diagnostics on the instrument cluster and check for errors on the transmission but nothing on engine management. I also tried to use the global odb2 options for the 2500 and no luck.... Has anyone ever seen this before? I'm wondering if I'm having an engine ecu failure?
This is on a 2003 e500 w211 with 71K on it.....
I've had this thing since October ( 3 months) and I'm already regretting buying it.... in the 1st 300 miles had a radiator failure which took out the transmission.... the service contract fixed it but it was 6 weeks before I saw my car again... 6 weeks of driving a rental.... which the service contract covered but still....
Old Jan 21, 2011 | 07:16 PM
SZMB's Avatar
2004 E500 CLK320
You may want to take the car to a local indy shop that specializes in MBs. You need to get the codes read.
Old Nov 20, 2016 | 07:43 PM
tritron's Avatar
cl500
Did you get this read after 5 years ?
Old Nov 20, 2016 | 09:13 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
SterlingG SterlingG is offline
Last Activity: 06-07-2011
My guess - the car is junked
