E-Class (W211) 2003-2009
FSS Main inspection performed on time?
Old Jan 23, 2011 | 05:04 PM
yoni111's Avatar
e320
Hi
Can anyone help me with this (Main inspection performed on time?) shows up on my FSS 2003 E320 is there a way to clear it without dealer.
thanks for your help
Old Nov 25, 2011 | 05:53 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Hey did you ever get that warning cleared? I thought i could clear it via the confirm, but i cant.
Old Dec 7, 2012 | 02:18 AM
georgedaman's Avatar
GL350
Old post but might be helpful for someone.
I had to reset the "Main inspection performed on time? " message twice in a few years in my 03 E500
First time just did it from the cluster..just set a further date on the SPECIAL WORKS section.
Same message came up just now afew years later ,googled the problem (since i forgot how i've done it before..) and found my own posting.
The above method didn't work this time though.
Broke out the " Star" , went into the ASSYSt menu and noticed ,there are 2 colum under a tab called "Setting date" or something similar.
One was the exhaust ( which i was able to set from the cluster before), and the other was the actual "Main inspection , which i did not even find from the cluster..so i had to reset the time from the Star.
Basicly the message "Main Inspection performed on Time?" refers to 2 items but only one was accessible through my cluster..
