E-Class (W211) 2003-2009
Suspension Control Arm Help..
Old Jan 23, 2011 | 06:12 PM
dsm2925's Avatar
W211
My e500 makes a clunk noise when i hit a pot hole on my front left corner. I thought it was a bad ball joint but i believe it the below(see picture).
there is a round hole on the front control arm. There the shock is bolted to the control arm.
In my case it seem like the rubber and metal tube that goes inside the contril arm shifted. forward and seems like the shock is rubbing against the control arm.
Question
1. is the part sold seperate from the control arm?
2. if i replace the control arm will i have to recalibrate my airmatic?
3. can i do this job my self?[ATTACH]Suspension Control Arm Help..-sspx1220.jpg[/ATTACH]
Old Jan 23, 2011 | 06:36 PM
konigstiger's Avatar
'71 Pinto
Control arm bushing (103 in diagram) is part 2113331914 http://www.autohausaz.com/search/pro...ber=2113331914
DIY LCA
http://www.benzworld.org/forums/w211...ml#post3416632
File Type: pdf
Old Jan 23, 2011 | 08:17 PM
dsm2925's Avatar
W211
Thanks for all the helpful info.
Do you think i will have to recalivrate the airmatic afterwards?
Old Jan 24, 2011 | 12:59 PM
dsm2925's Avatar
W211
Can that be installed without removing the control arm? Is it hammered into place or so i need a press?
