E-Class (W211) 2003-2009
Old Jun 12, 2015, 07:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Keyless Go door entry problem
Old Feb 10, 2011 | 07:55 AM
bacnberger's Avatar
2003 c240, 2008 e350 4matic
Now that my radio is fixed I am having a problem with the drivers door handle keyless go function. When I pull the door handle the car makes the beep sound and flashes the lights but doesnt unlock the door. If I pull one of the other door handles they work properly. It almost seems like its locking instead of unlocking the door. The handle was replaced about a year ago at the dealer but the car is no longer under warranty so its my problem now. any ideas?
Old Feb 10, 2011 | 12:54 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Your going to have to visit the dealer at some point to have this problem rectified.
Old May 9, 2011 | 07:12 PM
mbnj's Avatar
'06 E 350 4matic wagon; '05 E 500 4matic sedan; '09 S550 4matic
Did you ever get this one diagnosed/fixed. I have exactly the same problem and was curious as to what you found before I head for the dealer $$.
Old May 10, 2011 | 01:14 AM
Buddy Rabbit's Avatar
2007 silver e550 p2 pano sport
I went to the dealer (2007 e550) and they replaced the door handle.
My symptom was when I approached the locked car, the door would not unlock unless I pressed the 'unlock' on my key.
Old May 10, 2011 | 11:38 PM
mbnj's Avatar
Buddy/anyone, any idea if it is a DIY job to replace the handle?
Old May 11, 2011 | 01:31 AM
Can't help ya there. Mine was warranty.
Old May 11, 2011 | 06:05 PM
bacnberger's Avatar
I changed mine myself. There's one screw to remove that you will see the hole for if you open the door and pull back the weather stripping by the door handle area. The rest is sliding the handle out and disconnecting the plug. Here's a post that shows how its done https://mbworld.org/forums/w211-amg/...ement-diy.html
Old May 11, 2011 | 07:19 PM
mbnj's Avatar
Thank you.
Old Jul 25, 2011 | 05:18 PM
hanibal007's Avatar
E500-2007-V8-HP382-37000km-keyless entry/go-pano roof
I have almost same problem. Sometimes when I pull driver's door handle it unlocks car, sometimes will not respond and I have either to pull any other door handle or use the unlock botton on the key.
Will keep you informed
Old Jul 25, 2011 | 08:45 PM
bacnberger's Avatar
Thats what happened with mine. Eventually it won't work at all. Best price I found for the handle was at bmwmercedesparts.com. $131.10 plus $8.50 for shipping
