HOW TO FIX SCRATCHED/SPOTTED NAV SCREEN
I swapped some screens before and can help if you need!
14' C300, '07 G500 & '02 C240
Will this technique work on a 2013 C300 without the command screen? I accidentally scratched some of my anti-glare off and suddenly I scratched it. I was amazed. Trying to clean my screen and this happens. I mean I can live with it but I don't know if they use this same coating on a 2013 screen. Any ideas?
My car does not have the Multimedia Package with the larger screen its just the smaller screen with the Becker Map Pilot.
#33
#34
Thank you for this solution to the scratched Nav screen. It worked like a charm.
[QUOTE=srosenman;4525553]I'll cut to the chase...2009 E350 4-matic AMG Sport, Iridiumn Gray/Cashmere. Love the car, passionately. Idiot detailer sprayed something that completely spotted and messed the nav screen up...it ate right through parts of the anti-rflective coating on the screen. I have conducted more research than I care to get into. This is the definative way to get your screen looking brand new:
First, if scratched, worn or marked up from chemicals, there is only one way to fix, that is to remove the rest of the AR coating.
1. spray Novus plastic spray cleaner #1 on cotton or microfiber cloth. Give the screen a quick cleaning to remove dust/debris. Dry off with soft cloth.
2. squeeze a tiny amount of Novus fine scratch remover #2 on cotton cloth and work into entire screen in circular motion (good to do small areas at a time)
3. Buff dry with soft cloth
4. Repeat 2 and 3 until all coating off and you have a even, brand new looking screen.
5. Do #1 again to clean off to a great showroom shine.
6. Done - PS no need for AR coating...your windows and sunroof have it and the interior cabin glare is minimal. If you want protective barrier, you can opt for a NuShield product. Dont need it in my opinion...[/QUOTE]
#36
