E-Class (W211) 2003-2009
Questions??
Old May 9, 2003 | 10:30 PM
randomx5's Avatar
Question Questions??
HEY
i have a 2003 E320, with a build date of dec 02. Do i have to change the engine motor mounts? Also does anyone know of anyother common problems with their E320.
Also i have the audio upgrade and i wanted to know if the volume of the audio system should automatically go up depending on the noise, for example opening the window while the car is in motion. i thought this car had this technology, i was wondern if only my car did not do this.
Thanks very much
Old May 9, 2003 | 10:38 PM
RJC's Avatar
RJC
Various
I beleive the six's are exempt from the motor mount TSB. Look in your owners manual for auot volume compensation settings etc.
Old May 10, 2003 | 04:31 PM
rickyfanmdr's Avatar
2003 E320
I haven't had any problems at all, including motor mounts--just a musty smell from the A/C system when the A/C is turned off (they recommend you always leave the A/C system on).
You can have Harmon Kardon and turn off the Logic 7, as I recall. You might check your settings to make sure the Logic 7 system is turned on.
