E-Class (W211) 2003-2009
2008 Mercedes E320 Bluetec
Old Mar 10, 2011 | 06:01 AM
austin1705's Avatar
2003 Mercedes C240 2008 Mercedes E320 Bluetec
Hey guys ,
Anybody knows how you can fix the check engine light on my Mercedes E320 Bluetec or how much it costs ? Is a DIY or I have to go to a dealer ? Car still running smoth .Thank you .
Old Mar 10, 2011 | 07:03 AM
06e320cdi's Avatar
2008 ML320CDI
It is probably worth it to pickup a $100 code reader if you are concerned about costs. It may be something as simple as a MAF which you could change yourself, or even a loose fuel cap. But without reading the code thats causing the CEL there is no way to tell.
Old Mar 10, 2011 | 01:23 PM
lkchris's Avatar
'10 CL550, '12 GL550
Most 2008s are still under warranty--this is a warranty fix whatever it is.
It CAN be a loose gas cap, of course.
Old Mar 10, 2011 | 02:31 PM
dtrentr's Avatar
E-320 Bluetec
I've taken my GMC products to Autozone and they'll read the codes for free. I would imagine they'd do the same for your Bluetec, but I'll bet whatever it is they won't have the part and unless it's something silly like the gas cap you're going to wind up at the dealer.
Old Mar 10, 2011 | 07:02 PM
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by austin1705
Hey guys ,
I would not ignore it; CEL is there for a reason. Take it to any dealer if you are still under warranty assuming the car has less than 50K miles on the clock.
CEL will eventually go away if it is due to gas cap only; anything else means it needs attention.
