E-Class (W211) 2003-2009
Key programming..Please Help!!!
Old Mar 20, 2011 | 12:48 PM
slazzara's Avatar
2006 E350
The key for my 2006 E350 will lock and unlock all the doors and open the trunk. It will not start the car. Is there a way for me to program this without taking it the dealer? I can't even turn the key. It just allows me to stick it in. It seems like it's just locked.
Any ideas would be greatly appreciated!!
Old Mar 20, 2011 | 01:22 PM
High Technology's Avatar
2020 GLC300 & 2009 SL550 (previously had 1999 CLK / 2006 E500 / 2011 GL450)
Does your other key start the car?
- If so, then the issue is with the key or key programming in the car, and not the car itself.
- If you can't start the car with either key, then the issue is with the car itself.
Assuming the other key does start the car, the only thing I could think of trying is to start the car with the working key, then turn it off. Then put the non-working key in the ignition slot and let it sit for a while, perhaps even an hour (I doubt this will work, but it's something I saw several years back that was tried by someone else).
Old Mar 20, 2011 | 01:50 PM
slazzara's Avatar
2006 E350
the other key does work..I'll give it a shot and let you know how it goes..Thanks for your help!!
Old Mar 22, 2011 | 05:54 PM
bsvensson's Avatar
hers E350 / his E55
this is what I saw with others having similar problems. I don't know if this works or not as I have not had this issue.
"quote"
Thinking about this some more, I see two possible reasons for this working. I cleaned the little window on the key fob and ignition switch but I also pushed the window into the switch with the Q-tip. I'm not sure which did the trick. Yesterday, the key would not turn twice. I used the same technique. It took 4 or 5 tries to get it to work this time. Since someone's auto club got their's running by inserting a ballpoint pen in the ignition switch window, I am thinking it must have been that action that really allowed the key to turn. I'm going to replace all or part of the switch and/or key fob.
"unquote"
Old Mar 22, 2011 | 07:10 PM
Barry45RPM's Avatar
2015 ML 350
I believe if you change the switch (for which there are no replacement parts), you will need new keys to match the switch.
Old Mar 23, 2011 | 03:01 AM
Diesel Benz's Avatar
Sounds like the "power pick-up coil" in the key has lost contact. Disassemble the key and check carefully the soldering for the coil.
