E-Class (W211) 2003-2009
Where to buy H7 55W Low Beam Light Bulb
Old Jan 10, 2015 | 04:53 PM
Mackhack's Avatar
Originally Posted by cetialpha5
Bixenon's are brighter, but are only good for 2500-3000 hours. They also dim with age just like halogens. I'm tempted to get a new set, but there's a lot of fake ones out there and the fakes might not be as bright as OEM so I guess I'll wait a bit longer. Curve illumination is also pretty cool, but it's only noticeable on dark roads.
Certain things should kit be bought on eBay. That's all I can say. Sometimes buying cheap means you're paying twice. Brake and lighting equipment are some of the things where I suggest going OEM is the best way. Maybe more expensive but it will pay for itself.
Old Mar 7, 2015 | 09:59 AM
rosswell's Avatar
S320 GL350
Just off to buy one at the local NAPA - for my 1995 S class.
Manual says H7 55W. The Old one (made in Germany) is likely factory original and is a Phillips.
(B913 DOT 12972). I'll probably pick up 2.
Used to have CLK 320 with Xenons - and I bought the bulbs always from the dealer (they were $120 each).
