Need your help folks E240 2003 URGENT
Dear i am new member here i like this site it's great one >> let me summarized my problem since 10 days ago i change engine oil cooler because oil cap shown me an oil mix with water like milky.
After i replace engine oil cooler i change also engine oil (focus super GT Maybe not enough good) 6.5 liters and i check the oil on the cap surface it's seems to me good and the mechanic told me check within few days any white color will be disappeared and this happen and every thing going will for 7 days but again before two days ago i found a minor white color again on the engine oil cap ?? also the system ask me to add 1 liter engine oil after i check on internet i found that my car should be refilled with 8 liters so i add 1.5 liter but i don't know how i can check the oil level or reset system because the system still warn me to add on liter
Please i am waiting your advice friend note that's i don't have over heat engine just 80-100 clisues degree and no upnoraml colors comes out from exhaust tail.
We do not get that engine in the US spec E cars. Still, the symptoms you describe could be a bad head gasket. That allows coolant to mix into the oil.
As for the oil, you really need to check with a shop tool dipstick
I do not know the full level required for this engine but it should be found somewhere (on the internet). The dip stick tool is available at
www.baumtools.com
Good Luck
www.baumtools.com
Good Luck
