NTG1 COMAND APS inside
Just in case someone ever wondered how a NTG1 COMAND APS looks like from inside. I had a bunch of them here to fix the CD/DVD-ROM drives which gave the user the infamous "Disk Error"!
DB, you can't fix the laser unit b/c they have to be calibrated and have to match the firmware. The firmware knows how to slide the laser unit back and forth for this particular drive then.
I got a bunch of different drives for different models from my buddy who works for Harman/Becker in Germany. You have to swap the hole drive although I heard that some just swapped the laser units with cheap copies. But it causes problems b/c they are not calibrated and matched with the firmware.
It's like you can put new tires on your rims but without balancing the wheels it's not one smooth unit. Makes sense?
About the price you know where you find me as I can't post it here b/c officially you can't buy the parts. One would have to send the COMAND in for repair. Same with the firmware update 28/08 which is not officially released. The swap takes some time if you don't wanna break something. Bunch of plastic parts that hold the front together with the metal case. 2 Screws and 2 metal pins are used to secure the bezel to the casing
Hi, I need a help and I don't know if this the right place to put my question but I didn't find anything similar...I own a second hand W211-2007 (E200 Kompressor) VIN No. WDB2110411B125180 with NTG 1 COMAND APS factory fitted in Europe. Everything works perfect except audio cds. The system recognize and play DVDs in MP3 format but don't recognize CDs either music or MP3. When inserting CD after a few seconds display the message "DVD error". Pushing AUDIO button two tabs appear" 1) RADIO (which is selectable) & 2) CD (which is fade and not selectable). In a few words the system plays perfect whatever is written on DVD-R disk (MP3 or video) but does not recognizes CDs. It behavies like to expect all the times to read only DVD disc...First owber is an old man and he cannot understand the difference (I think that never used CDs or DVDs!!!). My local official workshop checked the COMAND system by STAR and they said that everything looks normal, no error codes, so obviously the system does not support CDs!!!
When the unit is switching on the screen display's both logos of DVD disk and audio CD Disk, while the manual of course describe the CD operation as normal...I consider that MB technician is ignorant but I don't know what to do further... Anyone with similar problem? Any ideas?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Your DVD-ROM most likely died. Many become defective and need to be replaced. I replaced mine a few months ago after this and it reads everything again just fine. If you need one I can check with my Harman/Becker source if I can get you one.
Alternativelly a CD changer could be fitted, isn't so? If yes what would be the cost?
Mine didn't read CDs but DVDs and Dual-Layers just fine. Reason is simple: The drives have 2 laser diodes for 2 different wave lengths. The laser for CDs was defective, the other one was fine.
Sounds perfectly fine that your dealer doesn't have firmware to flash it. Why would they? What should flashing of software do if hardware is most likely defective?
My suggestion means what I said: replacing the CD/DVD drive, NOT the entire unit.
When the unit is switching on the screen display's both logos of DVD disk and audio CD Disk, while the manual of course describe the CD operation as normal...I consider that MB technician is ignorant but I don't know what to do further... Anyone with similar problem? Any ideas?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
CLK 270 Cdi 2004
Here is my little problem; when drive the car and it get hot after an hour driving, my comand APS NTG1 would not read the DVD map for sat nav, it says "please insert DVD" when it is already inside... I presumed it is dying.
So I have removed and opened my comand unit, and took the DVD player apart, I have noticed that the picture of your's is the same as mine. on the label it is written: 32700-02600700 DV-01-26 NC102290 nearly same reference.
Do you know how I could buy a spare one to fix my problem ?
Thanks you
I can get you a drive if you need one! Pricing via PM though.
BUT: The map DVD is in the trunk, not in your COMAND APS!!! I had the same issue. It is a thermo-problem of the DVD drive inside your navigation processor in the trunk.
CLK 270 Cdi 2004
hi Mackack, and thank you for your reply.
In my CLK it is not like in E class, the DVD map drive is part of the comand unit and in the glove cabinet I have a 6 cd drive charger. I 've opened the comand unit and the DVD drive is the same as the one in your pictures in the top of this thread, as I wrote above, on the label it is written: 32700-02600700 DV-01-26 NC102290 nearly same reference...
And it is a thermo-problem of the DVD drive, it works OK a few hours and after parking in the sun a few minutes it would not read the DVD map. So I am going to send you a PM thank again.
How much would it cost to replace the DVD drive in my Comand? The mechanism that accepts/ejects discs works intermittently. When I can actually get a disc in there, it plays CDs/DVDs perfectly.
(Tried to PM you, but your inbox was full)
E420CDI 2008, GLK220CDI 2009
Hello
I am interested to know how it is possible to know which type of "Command" is instalklled NTG??? and which version of the Maps
I remember that before this thermo problem occurred, I found white powder flocks on the navi dvd itself. I cleaned the DVD and reinserted it. After a while there was again white powder on the DVD. Cleaned and repeated again several times. The powder finally stopped appearing.
I now have the suspicion that the drive unit itself is probably fine but there must have been 1 or more elco's that popped. That is also a temperature problem but shows poor quality in the pcb components of the navi unit. I am planning to have the navi unit removed and inspect/replaced elco's in the pcb. I need to ask MB to remove the unit for me since I don't now how to open the upholstery and whether I can drive without the unit and loose connectors.
Any advice/comments and help very welcome !
It's not a capacitor. The first units had a known fault. It had a faulty/wrong thermoresistor. I get smite information on Monday about it from Harman for you. But my advise: buy a new drive and replace it. I can get you one if you want.
