Things to get inspected/checked on 03 E500?
Anything else I should make sure they check while they're in there?
The motor mounts (2 motor mounts, 1 tranny mount) usually need to be replaced at 80/160k miles, along with a couple suspension related parts (i forget what they are called, but probably the bushings).. Also at about 80/90k(160k/190k) you may need to replace your valve cover gasket, along with plugs and wires.
I would have them replace the tranny fluid too, if its been awhile... I'm sure somebody else can come through with exact info for you.
