Radio glitch again
- Radio spontaneously turns off
- Reset fails
- Reset a minute later turns it on again
- Then it spontaneously starts playing CD instead of AM radio
- Off and on again fixes it
So now I am afraid that the fix was not complete and I'll see more malfunctions...
Michael
In my case somewhat different - I was not playing a CD but AM radio when it powered down; plus the CD is a standard CD - (Getz/Gilberto, Bossa Nova from around 1964, including "The Girl from Ipanema". Not that you're interested!)
So this will my second visit to the shop regarding the audio system (the first was due to the clock soft button being dimmed out and therefore unusable, which was due to a fault GPS antenna... which, during replacement of the rear glass to replace the antenna, they scratch the paint around the glass!).
I really love this car, but these little annoyances are starting to build up... I mean, I've had more issues with this car in 6 months than I've add with a Ford Expedition in 2 years.
Ugh.
Ugh.
MW
One day after I got my car back, the radio just glitched again - same glitch I had last week just before the Tele-Aid and SRS failed:
- Reset fails
Michael
i'm sure the dealer will eventually get it fixed.
Mark
But would you say that those service trips were all related to the electrical/tech stuff and not so much the guts of the car itself? Maybe your Expedition was the same way?
Yes, I would agree that it probably has to due to the high-tech nature of this car that uniquely separates it from the competition. But the Ford was just plain wierd, what with the wipers just going off by themselves (and they weren't rain-sensing).
Personally, I think it's a glitch in the fiber optic network, since I've heard loud static throught the speakers right before something went wrong. Maybe it is an amp overheating , but since it has affected different components my guess is it's the network's ability to handle power surges (the CD changer is no longer powered/recognized).
But when the audio system works, I have to admit that it's great
- Turns off spontanously while palying radio (FM this time)
- Then unable to turn it on for a minute
- Then I can turn it on again
- Then after playing radio for 2 seconds it spontanously starts tp play the CD
- Then I can turn it back to radio
So... all's not yet well. More modules to exchange.
MW
These problems have been common with the audio. It is supposedly a problem with overheating of the unit in the trunk. MB is working on both a software and hardware fix, but it was not ready as of last week.
Michael
You Will have one glitch.
It is associtated with the HK logic 7 system reported by me in another tread.
Basicly the HK surround sound system, when in the LOGIC 7 mode FM or CD playback, has a glitch in ALL NEW E CLASS CARS as confirmed by MB Factory techs. that involves the RIGHT REAR DOOR AND HAT SHELF speakers to "cut in and out" like a bad speaker wire connection ONLY IF/WHEN the fader is full AFT and ballance is FULL right or one segment left of full right.
rT\ Mercedes-Benz (~
'<:::;:~' star bulletin
.~I.
Date: Ma
y27 2003
DTB '
Order No.: P-B-82.60/215c
Supersedes: P-B-82.60/215b dated March 10, 2003
Group: 54
Revision: Procedure Updated
SUBJECT: Model 211.065/070/076 Model Year 2003
Intermittent Loss of Sound
If you receive customer reports in the above vehicles of the audio system having the following conditions with Audio Gateway (AGW) OTC code 0004 stored (control module was switched off due to excessive temperature), the AGW software may need to be updated.
. Intermittent audio
. Audio head unit locks up
" Audio head unit displays "black screen"
Software Update Procedure
1. Verify current AGW Hardware/Software version
Select the correct model Select Control Units
Select Information and communication
Select Audio, video, navigation and telematics
Select AGW - Audio Gateway (MOST network management, diagnosis gateway, radio tuner)
Select Control unit version
rn Note: AGW part number (listed as "MB object number for hardware and software") and SV'J status.
Software updating is possible on all AGW part numbers except 211 820 61 89 (Basic) or 211 820 62 89 (Logic 7 -Sound). If the vehicle is equipped with either of these, then the AGW must be replaced prior to the continuation of the software update procedure.
SW prior to 14/03 on eligible AGW's requires a software update.
If the AGW already has a software status 14/03 and a OTC 0004 is stored, please contact the Technical Assistance Center via authorized dealer personnel.
This bulletin has been created and maintained in accordance with MBUSA-SLP 5.1, Document and Data Control, and MBUSA-SLP 16.1, Control of Quality Records.
~. @ 2003 Mercedes-Benz USA, LLC. AJI rights reserved. Reproduction or translation In whole Mercedes-Benz Canada, Inc. or in part Is not permitted without authorization from the Dealer 'v\Ior1<shop Servl~$ publi$her. Printed in U.S.A. w.wI.MBUSA.com 1-800-FOR-MERCedes
