E-Class (W211) 2003-2009
E500 Won't Crank after Transmission Gasket Replaced
Old 05-06-2011, 08:46 AM
kaybal's Avatar
2003 E500 (W211)
Question E500 Won't Crank after Transmission Gasket Replaced
Hello guys,
I dont know if anyone has experienced this before. But My 2003 E500 will not crank or even turn-over after my the transmission gasket and mount was changed. The car was running great before.
As soon as we changed the tranny gasket and mount and tried to crank the car, nothing happens.
Please help on this..
Thanks.
Old 05-07-2011, 09:02 AM
starbrite's Avatar
2004 E320
I'm assuming you mean the gasket between the tranny and the engine.
That symptom would indicate that the gear selector is somehow misaligned, because the car will only start in Park or Neutral. Did you disconnect it when changing the mount/gasket?
Old 05-08-2011, 11:50 AM
kaybal's Avatar
2003 E500 (W211)
Thumbs up
Thanks, it was the neutral switch selector..
Fixed now.
Quick Reply: E500 Won't Crank after Transmission Gasket Replaced
