2007 E350 4Matic Xenon Headlamp
Scanning for diagnostic fault codes, none are present relating to the lighting (no fault codes in either one of the front SAM's) in any control module. I have swapped the headlamp control modules from left side to right side with no change.
Is this likely to be a mechanical fault inside the headlamp assembly? If so, does anyone have experience repairing this fault (as opposed to replacing the assembly)?
Any suggestions and advice to this matter would be very much appreciated.
Thank you,
Winf
