One side is lower than the other.
My rear suspension is about half an inch lower on rear passenger side than on rear driver side. I've look around today with soap and water, seems to me there is no leak is the hoses or anywhere. Anybody knows how to set or reset rear stabilising unit electronics ?
When I wake up every morning, the passenger rear side suspension is completely dropped. When I start the engine, it comes up in about 30 seconds.
Anyone has an idea what this can be ?
Thanks very much !
This is how the part looks on w211.
Good scanner will have option of inflating 1 bag at the time, so giving it time you can see when it goes down.
I have a 2006 E350 wagon which drives perfectly.
Yesterday i noticed that the passenger side, especially the rear, is very low...much lower than the driver side but the wheel is not touching anything and it still drives just like normal.
But looking at it I am not very happy.
1- Is it safe to drive, and if so...
2- I am due for an inspection and would it pass if it is driving normally despite one side lower than the other?
Thanks very much !
You do have a leak somewhere, this situation means that there is a leak and it is most likely the air bag, they are smaller then the front. If don't replace it, eventually your pump will go.
I almost guarantee it's the airbag. Have done any work to the suspension? If not its going to be the rear air shock.
I will look in the shop tomorrow, i might have one.
The sway bar bushings going bad could be responsible as well.
I have the same problem, my 2008 E350 Wagon is leaking air from rear leveling suspension. And during cold winter months, it lowers (mostly on the right side).
Not sure where there is a leak, but there IS a leak.
Can I just add a bit of stop leak fluid into the system?
Something like ATP-205 that typically seals rubber hoses and o-rings.
This:
Would this work?
If so, where (in this system) would I add the fluid.
If so, are there any problems that it can cause?
Has anyone tried this? Sounds like a no-brainer but I am sure there must be a reason no one has suggested it yet.
So, you are saying that the place to check is under the back seats.
Doesn't this assume that the leak is NOT in the airbag/airspring?
Since only one side is tilting, my sense is that the compressor (and the rest of central control) are okay.
With that said, if left for a while, both sides become low.
Let me know your thoughts please.
did you figure out the cause?? I also am hearing a clicking sound now in the back rear when pumping up as well as deflating, but it’s never slammed to the ground or anything
