E-Class (W211) 2003-2009
ABS, ESP warning lights and stiff steering
Old May 30, 2011 | 01:41 PM
royflip's Avatar
06 E350
I came across this problem after replacing ball joints. You need to remove the speed sensor to get at the bolt. If you don't put it back correctly, you get these warnings and stiff power steering. The metal bolt tab for the sensor has to be installed UNDER the plastic cover, not over....like I did. The STAR service dvd makes a big point of this, so I guess even the pros can miss it. Reinstalled, test drive, lights out, steering normal.
Old Aug 24, 2020 | 01:18 PM
Ben Holden's Avatar
2005 Benz E320 CDI
Yep, same thing happened when I put it back together incorrectly. Good to know. Thanks.
Old May 22, 2023 | 12:55 AM
restartbutton's Avatar
2007 s550
Is there a video showing how to do this? I'm guessing I'll need to take off one of my wheels huh?
