Is this true?
Most fuel-injected engines today use computer-controlled Deceleration Fuel Cut Off: When you lift your foot from the gas while leaving the car in gear, injectors shut off automatically, and the car's rotating tires—which are connected to the engine via the transmission—keep the engine turning and the accessories running. So, the engine consumes no fuel at all while the vehicle is coasting downhill.
In the early days of smog controls, some of the manufacturers tried to incorporate an idle circuit cut-off into carbeurators, too, but they were troublesome.
