2005 E320 CDI Questions
1. It is calling for Service E+ in 600 miles. I am not entirely sure what this will entail but I have gotten the E = about 5 hours labor. Please elaborate if you have more info.
2. I think it needs a thermostat. Operating temperature fluctuates quite a bit, never gets hot but varies from around 50-85, sounds like a thermo stuck open to me.
3. Front suspension makes some squeaks at low speed. Not really sure what this is at all. I am leaning towards tie rods. The steering wheel has some issues coming back to center at low speeds. Not sure if this is normal or not.
4. I am going to have to put newtires on it. Feels like it could be a wheel bearing but I think it is just the tires.
Anyway, this is a lot and I appreciate all the help. I am new to the Mercedes brand but I have always liked German cars. Overall, very pleased with the car. I enjoy the power and the economy of the diesel and I just couldn't bring myself to drive a Jetta.
You can pull up the items needed in FSS
Thermostat failure is fairly common. Replace and see you fuel economy improve. when I replaced mine it went up several mpg. Straight interstate driving my mileage runs 40+
Sounds like lower ball joints which is a known issue on W211s
4. I am going to have to put new tires on it. Feels like it could be a wheel bearing but I think it is just the tires.
Worn tires will sound like a bad bearing.
Hope this helps.
Replace motor and transmission mounts
Oil Change etc...
Replacing lower ball joints
transmission fluid and filter change
brake fluid change
drive belt replacement
What is a good price for all of these services?
