H&R 5mm front / 15mm back spacers installed! *Pics*
The front spacers are 5mm were $45 new and are not hub centric but as you can see in the picture, there is plenty of hub area for the wheel to go on so it's not a concern. The rear are 15mm were $90 new and are hub centric as the rear has a very small hub lip from the factory.
Also picked up new lug bolts that were measured to stick out of the back 20mm after the spacer was installed to match the factory bolts/wheels and turn 8x when tightened.
Tested to 85 MPH and no vibrations, everything works as it should. All four wheels are 18x8 ET35 w/ 245/40-18 tires BTW.
Stock front wheel hub.
Front hub with 5mm spacers.
New front wheel bolt.
Installed front spacers.
Rear hub.
Rear hub with 15mm spacer.
New rear lug bolt.
Without spacers.
With spacers.
