In sport shifting mode....
The driver adaptive learns your driving pattern and adjust the baseline transmission responses. However, there is no point that the DA will drop the transmission to a lower gear.
If the rpms drop too low, such as on a steep incline, the transmssion will slip to a lower gear.
Even if you do rapid acceleration it will only go progressively through the transmission, unless, you do the kick down (flooring it), then it will drop to the next lowest gear to wind the engine up.
If you typically drive slower and then pick up the pace, (I think) a kick down will snap the transmission out of your old pattern on hold the lower gears longer before shifting.
Also, how do I get the pic of my car to be placed below my name on postings?
Thanks!
This is just how MB has programmed the transmission. It is a little better in AMG cars. The more throttle you apply, the more quickly the transmission will respond to an upshift input. At full throttle, I think they should respond immediately, but MB decided to give the auto a mind of it's own.
On hard acceleration (foot ALL the way down), the transmission will not shift until redline, even if you nudge the shifter for an upshift.
Basically the transmission will not upshift even if you nudge the shifter to the right if it determines that more acceleration is needed.
It's hard to explain but I guess that's it in a nutshell.
