Cruise Control Died
What gives? Anyone know why the yellow triangle on the dash might come on and cause cruise control to not engage? I did not see any other warnings on the dash. I just got back restarted the car and the yellow triangle light is gone and cruise control now engages as normal.
Every single car I've owned has had cruise control and this is the first time that cruise control had died in a car I've owned
Okay so that's why out of the blue she asked me what ESP meant... I think she accidentally pressed it and then began to wonder what she had pressed.
Come to think of it that's around when my cruise control died!
It's good to know now that the triangle is basically a warning the ESP is off.
Not sure Mr. 4Matic would approve of the rear end getting loose on an acceleration binge by Ms. RWD alone... as he sends about 40% of all he has to Ms. FWD to keep things in balance
OK. Just had the same problem. Search lead me here.
Reading through this I saw another guy that had a similar condition to me. I had to jump start my 06 E55 to get it going. Just don't drive it as much as I should. After I got it going I put it on the battery charger overnight.
Yesterday I got the flashing cruise control arch.
After reading this thread I had an idea. I was thinking that some module did not properly reset after the undervolt condition, so I removed the negative battery terminal for an hour and reconnected it.
Just did a couple of drive cycles and all is as it should be. No flashing cruise control arch. So, someone else give the battery reset a try and see if it clears up the problem. Lets hope it is really that simple.
I had same issue on my C209. Cruise control sometimes repeatly blinked, when I turned it on, and when cruise control was turned of, some segments sometimes quickly blinked. Second problem was, that some parts of dashboard wasn't backlight right. For example aroun 7 on clocks or 160 kmh was backlight darker.
I bought three old clusters to try change components. And when I opened my cluster, i found, that the backlight unit is damaged on some places. It look like on this picture - black dots somewhere.
I changed backlight unit from bought cluster which had no black dots. Now, the backlight is same everywhere and that looks as the problem with blinking cruise control is done too.
First time a tought, thet the problem with cruise control will be in primary electronical board in cluster, but I can saw this problem, when I changed this board too.
