E-Class (W211) 2003-2009
Leak inside Front Right Well.. Help.
Old Aug 1, 2011 | 07:26 AM
kuch326's Avatar
2000 C230 Kompressor, 1999 SLK230 Kompressor
I have a 2003 E320 Sports and recently I've been seeing some signs that my front right well is wet or some liquid stuff is leaking somewhere. I jacked my car and see where is it coming from but couldn't find it. Anyone had this problem before?
I did a service before at the dealership and told be that I needed to replace bushings, are they the culprit to my problem? I asked them about it and they told me hydraulic fluid are leaking through the bushings, are they correct about it?
Old Aug 1, 2011 | 10:49 AM
Shadow5501's Avatar
Car free at the moment
The windshield washer fluid reservoir lives inside the right front wheelwell. Give it a few days and I bet you'll get the lower washer fluid warning on the dash.
It's an easy fix, though you do have to remove the plastic wheel well liner to access the reservoir. Could be a cracked plastic reservoir, could be as simple as the seal where the washer pump attaches to the tank.
Old Aug 1, 2011 | 12:38 PM
edwinwalke's Avatar
2006 E320CDI
Does the liquid stuff appear to be oil or water based? You may have a leaking shock absorber that is the culprit.
Old Aug 2, 2011 | 03:29 AM
kuch326's Avatar
The liquid seems to be between water and oil based. I have airmatic shocks, do they leak any kind of fluid??
Old Mar 29, 2012 | 07:12 AM
Gersh320's Avatar
E320 & X166
did you figure this out? My washer fluid is leaking for the second time in 4 years. The fluid runs out in front of the REAR right tire. Both times.
Old Mar 29, 2012 | 11:18 AM
foreyes's Avatar
2002 G500, 2007 CLS 550, 2018 GLC 300
I had the same leak behind the right front tire. I removed the wheelwell liner to gain access to the tank and then replaced the washer pump seal and the level sensor seal. It stopped the leak. Both parts were less than $10 from Parts.com
Old Mar 29, 2012 | 08:38 PM
Gersh320's Avatar
E320 & X166
Thank you!!
