E-Class (W211) 2003-2009
Fuel shut off valve location
Old Aug 6, 2011 | 05:07 AM
MEDICUS's Avatar
2003 E500
Question Fuel shut off valve location
Need help finding the fuel shut off valve location so that I can replace it. The dealership said that it was a problem and needed replaced so instead of paying almost $700 I am going to change it as well as a lot of other items. I just need help finding it. Has anyone replaced one of these before? I was told that when they were fogging my system it was leaking.
Old Aug 16, 2011 | 01:33 AM
MEDICUS's Avatar
2003 E500
OKay I found it. Here are some install directions.
1-Remove rear pass tire
2- remove inner fender cover
3- locate the evap canister above the muffler
4- disconnect the wire
5- twist out the fuel shut off valve located on top
6- change o-ring
7- reinstall fuel shut off valve
8- plug in wire or replace with updated connector
9-reinstall inner cover
10-put tire back on.
11 Enjoy knowing that it should have only taken you 30 minutes and you saved yourself
hundreds
