Factory fit rear screen mount problem
I have in my w211 a factory fit rear TV screen between the front seat mounted on the back of the centre console. The bracket is a bit looses I.e. It wobbles a bit and the screen sags. I have taken the screen off and have examined the bracket. The two white plastic bushes that grip the brass ball to allow swivelling have broken making joint loose and screen sag.
My question is can you buy the plastic bushes as spares from Harmon Becker the supplier of the kit ?
The rest of mount is OK and I hope it's bit of play can be tightened up. The dealer I believe will only supply the bracket A 211 820 0032 in the Color to match interior. Has any one had the same problem ? What is the price of the mount (A 211 820 0032 xxxx) ?
Thank you in advance.
Cheers
