E-Class (W211) 2003-2009
Old Jun 24, 2015, 12:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Electrical System
Print Wikipost
Keyless go starter button
Old Aug 15, 2011 | 11:59 PM
osunick's Avatar
Hi,
My E500 keyless go start button (in the shifter) doesn't work anymore. All other aspects of the system work properly, including the lock/unlock feature on the door handles. I've replaced the shift knob and button, to no avail. I've heard that there may be a broken wire in the shifter assembly that needs to get replaced. Does anyone know if this is the case, and if it's a DIYable repair? Thanks much in advance for any insight.
-n.
Old Aug 16, 2011 | 10:48 AM
E500 AMG Sport's Avatar
Possibly a bad brake light switch.
Common issue.
MSRP $10.50 @ dealer
Old Aug 17, 2011 | 12:38 PM
osunick's Avatar
I doubt that, doesn't the cluster trigger a warning if I push the button without pushing the brake? I get no response, it's as if the button isn't being pushed at all.
-n.
Old Nov 18, 2011 | 08:57 AM
slninja's Avatar
Plymouth Horizon ;]
-n.
Hey, just wondering what you ended up figuring out, if at all? - I'm having the same problem. At first I was able to jiggle it a little and it would work. Sometimes while turning on and sometimes when turning off, that's how I know it's not the brake light switch.
Old Feb 12, 2014 | 11:51 PM
absolutegtr's Avatar
2006 Flint Grey Pano E55 AMG
bump....I am having the same issue. The start button doesn't do anything whether the brake pedal is pushed in or not.
(Also, 3 of my 4 door handles do NOT work when trying to keyless open the doors, but I believe that the handles themselves are faulty.....as I went in with STAR and actuated each individual door to open)
Any updates?
Old Feb 13, 2014 | 02:26 PM
ok I have disassembled the shifter and the button and found the problem. Long story short I broke the very delicate switch.
PLEASE tell me Mercedes sells the START/STOP switch separately. If so, what is the part number?
Old Feb 13, 2014 | 03:30 PM
Well I didnt really FU the ignition switch it was broken to start haha
But yes I am talking about the actual ignition START/STOP button within the shfter itself.
And by god is it expensive for just a little switch! EDIT*** That is the wrong part...Here is what I am talking about:
Old Feb 16, 2014 | 04:07 PM
starbrite's Avatar
2004 E320
That piece is not available separately. The part #, which includes the boot is : A211 267 3510 9C05
Old Feb 17, 2014 | 01:43 AM
t-bone's Avatar
2004 E55
I have that part and would be willing to sell it. How much do you want to pay? PM me.
Old Oct 2, 2014 | 02:23 AM
dllhg's Avatar
2014 cls63 a amg. 2018 AMG GTR
Add me to the list. Everything works but the push start I miss that feature.
Old Oct 2, 2014 | 12:00 PM
starbrite's Avatar
2004 E320
See the sticky "KEYLESS GO wire broken" Probably your problem.
Old Oct 2, 2014 | 01:05 PM
neverclever's Avatar
06 e500 4matic wagon
That's a great sticky. The pictures make the shifter look like something you might design if you wanted to fatigue the wire intentionally I have keyless go and it is currently working, but I might take mine apart and wrap electrical tape around the wire to reinforce it where it goes through that hole. It's obviously just bending against that hard edge.
Old Oct 2, 2014 | 03:41 PM
Well that was interesting. The black plastic sleeve on mine had split all the way around but the wires were still intact. Coming out of the hole I folded the wires straight up and used a small wire tie to hold the wire to the shifter. Now the wire is in a graceful curve and not moving against a hard metal edge. If you haven't had a problem with your keyless go yet you might want to try this to prevent a much harder repair down the road.
Old Oct 2, 2014 | 03:47 PM
starbrite's Avatar
2004 E320
The only problem I see with that is that the wire moves back and forth with the movement of the shifter and now it doesn't. So it will flex every time you move it and, because the wires are so thin, they will eventually break at the flex point.
The solution I see, and one the factory should have used, is to put a small, split, rubber grommet in the hole.
Old Apr 16, 2015 | 09:24 PM
BGS273's Avatar
1982 300SD (OLD BLUE) - SOLD, 1987 190E 2.3-16V - SOLD, 2004 E320 Wagon
Button Jammed In
I have the keyless go and the button on mine is jammed in and does not pop back up. It's been that way since I got it. It does not affect the operation of the vehicle. It is kind of a bummer that I can't use the start/stop feature though...
Any ideas?
Old Mar 26, 2017 | 08:32 PM
Vetty Cap's Avatar
mercedes e500
Need this
call me 4077579008
Old Mar 26, 2017 | 08:33 PM
Vetty Cap's Avatar
mercedes e500
Need to replace mine
Please call 4077579008
yvette
