P0455 and P0336 Car won't start
Mercedes E350 RWD
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
I got those two codes and my car would crank but won't start. It most likely would barely start after number of tries. Could any of these codes cause this? Does anyone know what causes my car NOT to start? I tried to a fuel injection cleaner and it did not help...
Thanks all
Thanks all
does it just crank and crank and crank? If so, fuel pump and or filter would be my vote. Fuel filter is cheap and you can change it yourself, but sounds like the fuel pump is going out. This would cause your engine to just crank over and over but without getting fuel it won't fire.
Mercedes E350 RWD
JCat,
my car is from California and it is a PZEV car, and no filter or fuel pump sold separately. I was told I need to buy the entire fuel trunk, which retails at around $1,600. Do you by any chance know of any other cheaper solutions? If there is anything wrong with a fuel pump or filter, would it show any codes on diagnostics? These are the only codes I got, and I also got a code for Secondary Air Injection system, which I do not think has anything to do with starting the car.
JCat,
Do you have the information related to the codes? Those specifics may help in figuring it out.
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
The SAI system has a bunch of stuff:
(2) Shutoff valves (one for each cylinder bank)
(1) Check valve (intake manifold vacuum)
(1) Main relay (turns pump on/off as commanded by the ME-SFI engine control unit)
(1) Electric pump (powered by the front driver's side SAM module)
(1) Pump switchover valve (as commanded by the ME-SFI engine control unit)
A lot of stuff to oxidize HCs while waiting for the cat converters to lite-up!
Regards,
paul...
Regards,
paul...
04 E320
JCat,
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Post number two was correct----cps-----however to confirm all this you may want to visit a dedicated Sprinter forum----doa goggle---there are tons of em
I'm dealing with the same problem
I posted all my info but didnt find anything to help me.
The engine start with quick start fluid Read my post.
I changed crank sensor and camshaft sensor = no joy
Give me an reply if you find it. i'll do also
