E-Class (W211) 2003-2009
SRS light problem
Old Oct 14, 2011 | 09:40 AM
mak595's Avatar
e270
SRS light problem
My SRS light came on out of the blue, took it to a mate with a diagnostic and got fault 9920 "ignition circuit with component R12/9 (drivers side airbag ingition squib) has short circuit to ground"
any idea's regarding this fault before i start ripping the steering coloum to bits??
Car is a 03 E class 270 cdi
Old Oct 14, 2011 | 11:52 AM
konigstiger's Avatar
'71 Pinto
Remove seat back and check squib connector to side airbag harness - blue/yellow wiring with orange/green connector.
Old Oct 14, 2011 | 12:56 PM
mak595's Avatar
e270
Thanks, i'll have a look
Old Oct 15, 2011 | 01:13 PM
mak595's Avatar
e270
ok, checked the connector into the airbag & the main connector under the seat, nothing obvious but cleaned em and sprayed with WB40. if it was a dodgy connection, am i right in thinking the light would not go out on it's own and it would have to be reset via diagnostic tool?
Old Oct 15, 2011 | 05:53 PM
'71 Pinto
Correct, stored fault code(s) need to be erased using SDS. If problem persists, resistance value “may” be too high requiring connector replacement utilizing repair harness part # 0025402305
Old Oct 16, 2011 | 04:06 AM
mak595's Avatar
e270
thanks, i'l nip down to my mates 2morrow and see what his diagnostic says
Old Oct 18, 2011 | 04:17 AM
mak595's Avatar
e270
Sorted, reset code and the light stayed out, thanks again Konigstiger
Old Nov 14, 2011 | 04:50 AM
mak595's Avatar
e270
Damn, the lights come back on again after a couple of weeks guess i'll try the wiring repair harness, any idea of the price?
Old Nov 15, 2011 | 06:19 AM
mak595's Avatar
e270
Ordered a loom from MB, £19.99 so hopfully that will sort it..
Old Jan 18, 2020 | 11:10 AM
crizrodz38's Avatar
Mercedes w211
i have the same cod
i have to check that as well. will this cause my battery to drain as well? thanks
Old Jan 19, 2020 | 02:52 PM
b20guy's Avatar
I believe I’ve repaired this problem in the past by bypassing the X connector under the seat with the w220 X connector repair harnesses. No it shouldn’t drain your battery. This was a repair fix for the 209 clkS as I recall but also works for the w211
Old May 23, 2021 | 07:13 PM
Mikchek's Avatar
2001 S500 (W220) / 2007 GL450 (X164)
would this connector look the same on a 2007 GL?
you guys got any pics of it?
Old May 24, 2021 | 10:30 AM
'71 Pinto
