E-Class (W211) 2003-2009
Brake Light stuck on, help!
Old Nov 7, 2011 | 10:03 AM
LAWYER2's Avatar
15' W222
Drivers side brake light is stuck on with the following error message. "Brake light on" Indy mechanic says it's an electrical problem and suggested dealership. Stealership is saying $2k to repair but didn't say specifically what it was. (my g/f took to dealer, not me).
We did recently get the Brake warning light, visits workshop. We had the brakes replaced, but light returned soon thereafter. From reading the Forums, some suggested a faulty $11 brake light switch. Is this possible? Would the mechanics really not know this?
Old Nov 9, 2011 | 10:59 AM
LAWYER2's Avatar
15' W222
bump, for my poor battery
Old Nov 9, 2011 | 01:45 PM
Diesel Benz's Avatar
If it is only one brake light, then it does not sound like it could be the brake light switch.
What do you actually have on? The fault message indicates a back-up lamp is on, I believe in this case it means the rear parking light should be on when you press the brake pedal. But if the actual brake light is on all the time, it sounds like a SAM issue or a wiring issue, a short-cut to power from the brake light wire (doesn't that sound a bit unlikely?).
Old Nov 9, 2011 | 04:26 PM
LAWYER2's Avatar
15' W222
The only thing that remains on is the drivers side brake light when the car is completely off and locked. The above error message comes on periodically while driving.
Old Nov 10, 2011 | 09:28 AM
Barry45RPM's Avatar
2015 ML 350
Are we sure that the rear fog light is off? (in addition to the back up light problem?
Old Nov 10, 2011 | 09:53 AM
LAWYER2's Avatar
15' W222
honestly I can' say for sure. All I know for sure is the D.S. brake light stays on forever. It will not go off, and I don't know what else to do. To classify it just as an "electrical problem" seems extremely vague especially coming from the dealership
Old Nov 10, 2011 | 05:42 PM
Barry45RPM's Avatar
2015 ML 350
Check your headlight switch. It should be either on Off or in Auto, and pushed in all the way.
Old Nov 14, 2011 | 06:16 PM
LAWYER2's Avatar
15' W222
It's not the switch, thanks however.
Am I at the dealerships mercy on this one?
Old Nov 14, 2011 | 09:10 PM
chennney's Avatar
99 ML320, 04 E500
Check out my post:
https://mbworld.org/forums/4916327-post6.html
Fix should only cost you $40 and 30 minutes of your time. I'm surprised the dealership wanted to pull a fast one on you for this. Since I don't see a specific w211 in your profile, check EPC for the correct part number for your car.
Old Nov 15, 2011 | 08:54 PM
LAWYER2's Avatar
15' W222
appreciate the input. Was that fix for burnt out bulbs or reliving the error message? If the bulb was bad, shouldn't it not work as opposed to remaining on 24/7, or the fact that they're wired in a series and somehow supplying constant voltage to the DS brake bulb
Old Nov 16, 2011 | 01:08 AM
chennney's Avatar
99 ML320, 04 E500
The burnt out bulb directly causes this error message. You'll noticed that the error message doesn't appear when you first start the car. Only after you press the brake, does the system recognize the fault and display the message. Obviously this isn't an urgent fix because (as states in the error message) there is a backup -- it's just always annoying to see the perpetual errors.
You can't just replace a bulb because the bulbs are soldered on. I remember reading about another person attempting to replace via desolder/solder but I don't think it was worth all that trouble when you can get the entire socket plate replaced for $30-$40.
