Air Con low gas cut off
E200K-W211
Recently my air con compressor did not work. I took it to a normal air con repair shop and they told me that i needed to replace the compressor. I checked the manual and found out that i needed to go to the Mercedes center to reset the compressor to run the compressor. The gas was low but not completely empty. Guess this is to prevent compressor damage when run without gas. Appreciate if any of you know any other way of running the compressor by some other means. The compressor needed to be operated to fill in the gas. I have since resetted the compressor cutout (at Mercedes center) and refilled the gas. Thanks in advance
