Octane, in Canada
Where do you all buy gas, and what do you buy?
I used to run on Sunoco 94 Octane (European friends, we use a different measure of Octane here, namely R+M/2; 94 Octane in North America is equivalent to around 98 in Europe).
Anyway, that is the highest you can get here. Esso was 92 but has just gone back down to 91.
So why not stick with Sunoco? Ah. they use alcohol to get that high rating. Alcohol is not good for engines - it is essentially a solvent and will wear out gaskets and seals.
So now it is back down to 91 Octane for me?
Any opinions?
Michael
For your car sake, give her 91+. (I use 93 for my cars.)
Your new e does have a sensor to handle the different octane level gasoline but you have to take your own risk to fill lower grade gasline -- under 91 octane.
Offhand, do you know which other brands shoot booze into the fuel? I know almost nothing about this...
If gas company can promote its gasoline grade by adding alcohol; it will not only does for 94, it will does for 91 as well -- adding alcohol to 89 even 87 to get 91 gas. Don't worry too much about premium gasoline because both laws and gas company's reputation control the quality of gasoline.
I have not heard about that. I use Sunoco 94 once in a while because there is no Sunoco gas station in my town. By the way, it is illegal to add alcohol to gasoline according to NJ DMV so I don't think Sunoco can break the law.
MW
But here (Ontario) they advertise on the pumps, "contains up to 10% alcohol". It's cheap and clean - just wears away your seals and gaskets, I understand.
MW
Do you really think Sunoco would sell gas that would ruin your seals and perhaps then have a class action lawsuit headed in their direction ?
