Creaking noise(chassis flexing?)
Hopefully someone can narrow it down. I may take apart the sway bushings this weekend, I'll report back.
Smash
But, I will say that the sway bushings, which at first glance seem easy to get at, are not so simple. As you see, someone wrote here that it was his sway bushings that caused the issue, but I wonder if it's the chassis or the hub bushings? I think it's the chassis ones, only a guess. Anyway, to release the sway bar from the chassis bushings, it appears that both wheels need to be off and the hub connection removed. Then, the A-arms need to be lowered down approx 45 degrees - unsure if this can be done with the lower ball joint still connected, but probably. Then, the sway bushing housings can be unbolted from the chassis with 2x 10mm torx each side, the sway bar moves forward and down, and finally you can get at the chassis sway bushings themselves.
So no, I didn't do all that! I stuck a tiny screwdriver into the bushing and squirted some lithium grease in there (unsure how much really got "in"), on both sides. After a test drive, I still have some squeak, but it sounds somewhat diminished. Let me drive it a few hours over some bumps and see if the grease works in and if this provides an easier solution. It's quite annoying, but I'm not prepared to take any more off at this point. I'm changing brakes in April, so I will do it then if necessary.
HTH,
Smash
Thanks so much. I'm seeing my mechanic tomorrow(Tuesday), we'll talk about it and I will let you know what he thinks, what we do(if anything) and see what happens. I'm very appreciative.
2004wagon500
Car front end raised a bit.
Engine stand/lift used to take the weight of the engine off of the bar.
Old bushes..completely deteriorated and cut..were cut off..area sanded and cleaned.
New Bushes bonded in place.
I don't think this would be a DIY (?)
Again, thanks for all the suggestions. My mechanic took car for another test ride. Heard the creaking going over speed bumps....thought it was coming from the front of the car and hence would be the struts. Nonetheless, after reading all of your good comments, he pried the sway bar bushing on the right and put in some lithium grease. Couldn't pry the left one so he hit with some penetrating oil. Also greased the strut bushings. At least on the ride home, it seemed to have done the trick. He told me we could do this again in the future if it starts creaking again and it shouldn't hurt anything. I'll stay tuned for additional comments and will update if(when!!) the creaking comes back.
2004wagon500
I'll complete when I do my brakes here in a couple months.
Cheers,
Smash
Cheers,
Smash
Please take pictures if possible when you attack this DIY job and post pics if you would be so kind...
