V60 Phone & Sprint
Thanks for your information.
Will the v60 Tri-band phone work with an '03? And what is a "Tri-Band phone? I'll TRY to call sprint to see if it will work with their service.
You should contact your local SprintPCS service provider to see if the v60 is available in your area. It is not presently available in the Los Angeles area. Also, Mercedes is changing to the v60i tri-band phone; check to see if that works on your local Sprint network and buy that phone from your MBZ dealer instead. [/QUOTE
Where did you get the info that Mercedes was changing to the tri-mobile?
