E-Class (W211) 2003-2009
2007 E350 air filters.
Old May 10, 2012 | 05:10 PM
kensiko's Avatar
2008 GL550
I did a search but didnt find anything on the 07-09 models.
A video on youtube showed the filters to be in this plastic black box in the upper left and right hand corners of the engine:
So why did Advanced auto parts sell me this filter, which is obviously much smaller than whatever's underneath that cover...
Old May 10, 2012 | 05:43 PM
Kwijibo's Avatar
2007 E550 4matic
The filter in the upper left corner is the cabin filter.
The part you bought is an engine air filter, which mounts under the plastic engine cover.
Old May 10, 2012 | 05:52 PM
spyroz's Avatar
08 W211 E350 Sport Pkg. AMG Kits, Sienna Black Paint/Designo Tan Leather Pkg/Pano, Navi, Miro M.BLk
K&N for your engine Air Filter!
Old May 10, 2012 | 09:37 PM
kensiko's Avatar
2008 GL550
Well, first I pushed the metal clip off the rear. Then I just yanked on both covers like a raped ape until they popped off.
The two air flow tubes and a third tube in the middle (not sure what it does) just kinda came undone on their own, but it would have been just as easy to disconnect them beforehand.
Now my car is an 07 with 23k miles. As you can see, these filters are pretty bad. The replacement Purolators have fewer folds which means that they will trap less dirt but I change air filters once a year so Im not worried about it.
Old May 16, 2012 | 12:16 AM
spyroz's Avatar
Hey, I have an 08 W211 E350 and I'm about to change the air filter myself. So, you just pull the plastic cover off? the small plastic piece in front just pop out easy, but the rear is a little hard to pull out, i'm afraid I might brake something if I just yank it out like you did.
Oh, by the way how much did you pay for your engine air filter?
Old May 16, 2012 | 09:59 AM
kosmo's Avatar
2009 E350
the rear clip at the rear of the cover can be popped off w/ a screwdriver. When reinstalling the engine cover, clean out the rubber grommets and spray some rubber conditioner on it. If you dont have that, then use a mix of CARWASH soap and water. DOnt use DISH soap.
i paid $20.70 for the pair of airfilters. Hengst or Mann , cant recall.
to the OP, at 5yrs old you prob need to replace the in cabin filter. I paid about $20 for a carbon filter.
Old May 22, 2012 | 11:36 AM
kensiko's Avatar
2008 GL550
Dang I been busy, did you do it? I can def help with this. I should do a detailed DIY on this. Its always "easy" after the fact.
Old May 22, 2012 | 11:37 AM
kensiko's Avatar
2008 GL550
I way over paid for the filters. Got info on the cheaper source?
Old May 22, 2012 | 12:06 PM
kosmo's Avatar
2009 E350
I have 3 sources for german auto parts:
http://www.rmeuropean.com/mercedes-parts.aspx
http://www.europartsdirect.com/
http://www.autohausaz.com/search/mod...00016&year=All
good luck
