W211 Wagon - Where is antenna amp?
E320 2004 Wagon
Am looking for location of the AM/Keyless entry antenna amp for a 2004 E320 4Matic wagon. I understand it is in the headliner in the sedan but would like advice on how to find it in the wagon. I believe my shop either disconnected or broke it while fixing a rear windshield washer line problem.
Many thanks.
Many thanks.
Received 4,435 Likes
'71 Pinto
Located behind left d-pillar.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
The next step ain't simple unless you have a friend with a DAS Xentry(Star) diagnostic tool.
I say that because there are many electromechanical components that have to work correctly to open and close the vehicle---which one is not working---a huge guess without a quick test of the appropriate components. Then you start changing out components and that gets expensive with the possibility that the problem persists.
