E-Class (W211) 2003-2009
Replace Entire NAV Unit?
Old Jul 10, 2012 | 05:10 PM
NoFoolyn's Avatar
2007 E320 CDI Bluetec
Bought '07 E320 Bluetec 11 months ago, with 53,000 miles. Nice car. Have only used CD unit ( built into COMAND NAV unit) about 7 - 8 times, and thought the eject button was funny with disc not staying out very long before being sucked back in. Last two times was really quick, had to QUICK grab the disc, and pull out... with CD Error light coming on the display screen.
Last night, had to hit eject button 4 times to get disc to come out ( only barely ) and it stayed out on 1-2 seconds. Hit eject again, and grabbed small exposed portion and pulled... CD Error light came on again.
MB dealer tells me I need to replace the entire NAV unit at $4,700 plus $250/hr for labor.
I ain't just rolling over on this!!
Anybody have experience with this?
Thanx
Old Jul 10, 2012 | 05:44 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Wow, that dealer should be burnt to the ground. You can buy a brand new OEM unit for less than half of that and just swap it in yourself, it's plug and play as far as I know. Just be sure not to get the 2009 version, which was different and isn't plug and play.
Here's a used one as an example: http://www.ebay.com/itm/MERCEDES-BEN...vxp=mtr&_uhb=1
You should tell that dealer off and write on their google review page.
Old Jul 10, 2012 | 06:28 PM
Barry45RPM's Avatar
2015 ML 350
Thanx
If you're gonna shop around, its not the NAV unit... its the COMAND unit (Head Unit). NAV is in the trunk if you have it.
Old Jul 10, 2012 | 06:35 PM
konigstiger's Avatar
'71 Pinto
FYI
EPC shows part # is 2119060400 - parts.com new $3360, used you may want to consider http://www.fastoem.com/products/COMAND-BE7040.html (no affiliation, or experience).
Old Aug 2, 2012 | 12:03 AM
bamwo's Avatar
r350
w211 navigation
that's too expensive, you can consider to buy a after market navigation unit which is only $600 or so http://www.cars-electronics.com/2-di...oth_p1382.html
Old Aug 2, 2012 | 05:48 PM
apl175's Avatar
Used head units can be easily found on ebay. For the -08 Model years, there is no anti-theft circuitry to worry about. The entire head unit can be removed and swapped in about 15 minutes.
Use caution when considering an aftermarket unit, especially if your car has Harman/Kardon audio, and if you rely on the teleaid/Mbrace system. The wiring is completely different.
The only "upgrade" I would consider, if you do not use Sirius, is to switch to a head unit that has DVD playback. The "SAT" button is replaced by one that says "VIDEO" for this purpose.
