E-Class (W211) 2003-2009
HELP my fuel door won't lock
Old Jul 31, 2012 | 10:19 AM
altahhan's Avatar
w211 e220 cdi
I have E220 CDI 2005 which my fuel door won't lock
he was locking when I lock from the key but i didn't know what happened it seems in a big problem
I opened the boot trunk and release the lock and opened it it had a some motor so i put at him a small voltage and it works so the problem is not in the locker it is from a fuse or a n electric piece that is responsible to lock the locker
did anyone knows when can i find the fuse for fuel door lock and what is his number or if anyone know any advice that will help me fix it
thanks for every advice you will write
Old Jul 31, 2012 | 03:09 PM
altahhan's Avatar
w211 e220 cdi
help 240 viewers without any reply
I still need your help I filled my car with diesel and the fuel door won't lock
I need a digram or a fuse map to fix the problem
Old Jul 31, 2012 | 05:09 PM
konigstiger's Avatar
'71 Pinto
You can check f15 if fine “may” be relay G and/or H at rear SAM located behind left trunk panel towards wheel well.
Old Jul 31, 2012 | 06:07 PM
altahhan's Avatar
w211 e220 cdi
thank you very much i checked f15 and it was without fuse and i put a 15A fuse in it and everything does fine
I appreciate your reply can you just details me more about what is a relay G or H if you can
