E-Class (W211) 2003-2009
Problem with 2005 E500 after oil change HELP!
Old Aug 5, 2012 | 12:42 PM
olegna32's Avatar
2005 e500
Exclamation Problem with 2005 E500 after oil change HELP!
So Friday i took my 2005 e500 to the shop to get an oil change. They washed it and changed the oil looked great in the parking lot at work they brrought it to me when it was done. Now i go to get into the car after looking from a distance and saying looks kind of low i turn it on and i get the "Stop car too low" light on. Now my car is sitting in the lot waiting for the shop to come and get it monday morning. Please help me out what could they have done so wrong to my car!? all i wanted was a simple oil change any help would be greatly appreciated just so i know what to say to these guys when i tear them a new one!
Old Aug 5, 2012 | 01:04 PM
Lefix's Avatar
2003 E500
Well, our E500's have airmatic suspension, basically electronically height controlled "airbags"
The height can be adjusted electronically. But they shouldn't have touched anything that would've messed up your suspension height. Just tell them that and ask them what they did.
They could've messed it up, but it also could've been a coincidence where your airbag strut(s) broke/died because they tend to do that.
Old Aug 5, 2012 | 01:05 PM
novae500's Avatar
W211
Your airmatic suspension may have a leak or the compressor is going bad. Def take it to the shop for diagnosis. I would look into arnott shocks for front and rear instead of getting Mercedes replacement shocks!
Old Aug 5, 2012 | 01:40 PM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
Where was the oil change performed? A dealership, indy, or quick lube place? So the vehicle is down on all four corners. Did it rise when you started the engine? Could you hear the compressor running?
I've read some older threads about jacking the vehicle. When the suspension is reloaded and it's not done with the engine on and done incrementally, others have experienced a suspension failure.
Old Aug 5, 2012 | 06:11 PM
olegna32's Avatar
2005 e500
had it done at a local mechanic shop that claims they work on mercedes all the time. is it possiable that when they put it on the lift they some how may have clipped a line to cause a leak?
Old Aug 5, 2012 | 08:23 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
No, lines are not that easy to damage.
Old Aug 8, 2012 | 07:29 PM
PlatinumPi4u's Avatar
06' w211 E500 Sport
From 03 to 05 are known to have air suspension problems. Hopefully its just a hose with a leak, and the compressor isn't fried from continuous pumping... forum search tool (or big wallet) is your friend.. also try and go to a benz indy mechanic for everything, as it has been my experience that the generic shops often times DON'T know what they are doing... like disabling the SBC brake system prior to brake jobs, etc....
