E-Class (W211) 2003-2009
Sub install
Old Aug 16, 2012 | 07:04 PM
Celicasaur's Avatar
W212 - E63 AMG
Sub install
I'll bet this has been beaten to death a million times, but I've been looking on and off for the last 18 months and can't find a definitive guide to getting this working for me. I have a 2003 E55 with HK system, but I'd like to run my own sub.
Is it essential to have to cut wires and use that sound splitter thing that can be bought? I would like to know how/where to get the signal from and also, where on earth am I meant to tap the remote wire into?
Old Aug 18, 2012 | 11:55 AM
bacnberger's Avatar
2003 c240, 2008 e350 4matic
Pull up one of the rear door sills and you will be able to find the wires that run to the rear door speaker for that side, you can tap in there and run wires back to the trunk for your sub easily. Most newer amps have connections for amplified inputs so no other box thingys needed.
Old Aug 18, 2012 | 01:49 PM
Celicasaur's Avatar
W212 - E63 AMG
I take it that would be in order to give the sub it's sound signal? Thanks very much
Where would I need to connect the remote wire into?
Old Aug 19, 2012 | 12:37 AM
bernard farquar's Avatar
2011 E350, 1998 ML320
use an active line converter, such as this one.
http://www.audiocontrol.com/17612/64...l----LC2i.html
tap into the sub leads from the trunk side. the lc2i converter also gives you a remote turn on so you can wire everything right on the sub box, and get power and ground from the battery under the trunk floor.
Working great for me.
