E-Class (W211) 2003-2009
Navigation Help
Old Oct 10, 2012 | 07:45 PM
david5of9's Avatar
2008 MB E-Class 350
Navigation Help
does any one have any idea what to do if your Navigation say NO DVD Available, Please inert Navigation DVD. I purchase service disk 211 589 15 22 00 but it will not read. any help would be very appreciate.
2008 E350
Old Oct 11, 2012 | 05:59 PM
Barry45RPM's Avatar
2015 ML 350
Is there a map DVD in the unit in the trunk?
Old Oct 11, 2012 | 07:13 PM
david5of9's Avatar
2008 MB E-Class 350
Navigation Help
Yes;
I read here on MBWorld that if you insert a new DVD this may happen and to do the following " Get a copy of Service Disk (211 589 15 22 00) and do a Service update, but it just spins and spins then it states that "NO DVD Available, Please inert Navigation DVD" Now this happens with the Nav DVD and the service DVD disk. The Navi DVD is the newest one version 2013 w/code's
(Bq 6 646 0293) - (A211 B27 44 65)
Old Oct 12, 2012 | 08:36 AM
mtrevelino's Avatar
2006 E320 CDI
I am pretty sure that the service CD needs to be done in the main COMAND unit inside the car. At least that is how I did mine. Did you read the directions on the back of the CD case? If not, they are as follows:
> Turn on ignition.
> Ensure that there is no disc in the head unit drive.
> To start software updater press 1, 3 and 8 at the same time.
> Insert service update disc.
> After confirming the new software version the update will start automatically.
> After the update is completed turn ignition off and lock the car. Wait until instrument cluster turns off.
Good luck!
Mike T.
Old Oct 12, 2012 | 10:55 AM
Diesel Benz's Avatar
No, google a bit and you'll find that the CD 211 589 15 22 00 is for the navi processor. There is another service CD for the head unit (this is market area dependent), you must be referring to this CD but it does not help with the navi processor DVD drive.
The SW update is not needed for the navi processor either if the maps DVD is one of the latest ones. These have the firmware included again.
Looks like it is simply an issue with the DVD laser not reading DVDs, quite a common issue with these units.
Old Oct 13, 2012 | 08:15 AM
david5of9's Avatar
2008 MB E-Class 350
I google it and have read that I need service disk W211 589 15 22 00.
This is what I have done thus far, When I powered everything on...the unit was recognized right away (message on screen said "Navigation activated...Please wait". But, after waiting, I get the dreaded "No DVD Please insert a Navi-DVD (car trunk)" message. My map disc is 2013 (v12.0) and I fear that my Nav processor/unit may require an update in order to read this newer version. I bought the Nav drive from eBay, so I have no way of knowing what version maps it has seen. So, I tried updating it (with the update service disc, part number W211 589 15 22 00), but nothing happens when I put the disc in. It spins (I can hear the Nav processor working), but the update doesn't happen. So...back to the drawing board. Then the unit revert back to the "No DVD..." message again.
Old Oct 13, 2012 | 10:25 AM
Send the unit back to the Ebay seller.
Old Oct 21, 2012 | 06:43 PM
david5of9's Avatar
2008 MB E-Class 350
Smile
I want to thank you all for all your advise, I sent my DVD Rom back and got a replacement, the unit is functioning well and am loving every minute of it. Once again thank you all for your support / advise, and idea’s
David5of9
