Battery location.
Box where backup battery should be is empty with sticker for it being in trunk but do not see it there. I assume car should start without it. Turns over easily. Charged main battery without disconnecting. I assume backup battery has to be separately charged?
Not a fuel pumps problem? Flywheel position sensor defective?
Starter runs strongly but no gas or ignition. Main battery fine. Replace both angular position sensors? With 2 fuiel pumps is one enough to allow starting?
anything?
I was told to replace crank and cam position sensors with MBZ ones on this 90K miles car for reliability. And might fix starting problem.
