18x8.5/9.5 BBS LM style reps $529 *NEW* from PowerWheels Pro
Description: BBS LM style wheels
WHEEL SPECIFICATIONS
Price: $529
Size: 18x8.5 (18x9.5 35mm also available, add $20 in purchase price)
Offset: 35mm
Weight: ~24lbs
Hub size: 66.6mm (hub rings included)
Bolt Pattern: 5x112
Finish: Silver Polished Lip
Shipping: $85
WARRANTY
Our wheels are made at an OEM factory so we are proud to offer the following:
2 Years Finish Warranty: Many replica wheels finish can be sub par and the finish can crack or peel off. Since our wheels come out of an OEM process, the paint and clear coat thickness is similar to OEM standards.
Manufacturing Defect Warranty: The wheels are made in a low pressure casting process like OEM wheels do and go through rigorous quality controls including 100% x-ray, leak and balancing tests. They are guarantied to fit on your car without vibrations or pulling.
Fitment Warranty: You don't have to know the technical specifications of the wheels your car takes, you can lean on our experience knowing what fits your car. If we get it wrong, we will support you as much as we can, or we will take full responsibility and give you a refund.
The wheels are in stock and we can also quote wheel and tire packages.
We do not make money on tires or on shipping, it is just a service we offer to our customers, we recognize not everyone has the time to drop off wheels and tires at their local tire store and waste half a day to get them mounted and balanced.
We will mount and balance them for you and take on the risk of getting it right. We have had many customers that called us after getting their wheels mounted telling us that the tire shop scratched them and asked for replacements.
You can always call us at 248 686 2035 if you have any questions.
Thanks for looking!
Shipping to Sweden is around $400-$450 via Fedex
If you have a cheaper way we will be happy to work with you.
Once customer from Iceland had us ship the wheels to an airport facility in the US cause he could get them back home for less.
Just an idea.
Hi arekux,
Based on our sources, also confirmed on here:
https://mbworld.org/forums/c32-amg-c...ms-offset.html
Your stock wheels are 17x7.5 30mm F and 17x8.5 34mm R
According to the wheel offset calculator here:
http://www.1010tires.com/WheelOffsetCalculator.asp
These will EXTEND an extra 8mm outboard so clearance should not be an issue.
Thanks,
