E-Class (W211) 2003-2009
2003 e320 code
Old Feb 25, 2013 | 01:25 PM
bigbudha's Avatar
04 e320 sport
2003 e320 code
hi i have 2003 e320 with 69k mile check engine came on and i checked the code.
p0123 p0442 any help will be great.
Old Feb 25, 2013 | 04:41 PM
bigbudha's Avatar
04 e320 sport
Pultoe,
thanks my vin#wdbuf65j23a153156.
i checked the gas cap the plastic string that holds the cap was trapped between the cap and the tank.
Old Feb 25, 2013 | 10:18 PM
ozusa's Avatar
2004 E320 4matic Sedan
P0123
P0123 is a generic code: Throttle position or pedal position sensor/switch circuit, high input.
Now what does that actually mean? It may mean you have a bad throttle position sensor (and it may not). If your code reader is more than just a simple reader, it may be able to show you the behavior of the TP. The thing to look for is a steady transition (%) in the TP as you press the throttle through its range with the engine running. Not a jerky change in the %. A smooth press of your foot should result in a smooth change in %.
As for symptoms, you could get transmission or other issues with a bad TP sensor. If you have no symptoms of that, perhaps you could clear the code and see if it returns.
Old Feb 26, 2013 | 03:57 AM
bigbudha's Avatar
04 e320 sport
thanks ozusa
