E-Class (W211) 2003-2009
gearbox fault.
Old 03-04-2013, 02:39 PM
nav208's Avatar
W211 270cdid 2003
gearbox fault.
http://www.youtube.com/watch?v=j2WS7...ature=youtu.be
0:24
is normal? i have set Comfort mode. Sport mode is a little better.
if the car is cold, the transmission no shift. where is the problem? thanks for reply.
sorry for my english.
Old 03-04-2013, 08:36 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Don't worry about your English I can still read it fine bro. Shouldn't be normal to have any slip or shuddering, I would check transmission fluid condition, levels, and everything but it shouldn't be behaving like this.
It could be as simple as a transmission reprogram or this: https://mbworld.org/forums/e-class-w...se-advise.html. Since it's a 2003 it's especially vulnerable to glycol contamination that gets into the torque converter and can cause these issues. If it isn't shifting at all it could be a speed sensor problem or some other issue with the transmission. Try to get any codes pulled from an OBD-II.
Old 03-08-2013, 02:00 PM
samo1's Avatar
Mercedes Benz E320 W211 2004
I think it's normal.
In Comfort mode the car is moving from 2nd gear and also up-shiftings are done a little late (about 2000 RPM).
I haven't seen any issues in the video
Old 03-08-2013, 02:02 PM
2014 BMW M235i
If it's still shifting fine, if it lags a little bit than just do the sneaky reset technique that's been covered on the forum, but as samo1 said there is nothing wrong with it upshifting a little late as long as there is no loss of power or shuttering, as comfort mode is a second gear pull for smoothness/fuel-efficiency.
Quick Reply: gearbox fault.
