E-Class (W211) 2003-2009
Will C55 wheels fit on E Class Wagon?
Old Apr 5, 2013 | 09:21 PM
Peydidy's Avatar
C63 AMG
Hey everyone
I was just wondering if the 18 inch wheels off of the 2005-2007 C55s have to correct offset and sizing to fit a 2004 E class wagon.
I tried searching the forum and from what I read it should fit but I wanted to be 100% sure.
Thanks in advanced!
Old Apr 6, 2013 | 08:47 PM
AMGAffalterbach's Avatar
2014 BMW M235i
If they are the same bolt pattern, 5x112, and have a decent offset then it should fit. What are the specs?
Old Apr 6, 2013 | 09:49 PM
Peydidy's Avatar
C63 AMG
I was referring to the stock c55 wheels. They are OEM mb wheels so they are 66.5 hub and 5x112 bolt patern
I believe the offset is somewhere around 25-30 ET but I am not positive
My question is what offsets would be needed to fit a 2004 E class wagon
Thanks in advanced!
Old Apr 7, 2013 | 06:30 PM
2014 BMW M235i
The E550 4-Matic, I believe both have the same spindle design as they are all-wheel-drive, has stock wheels with a 33mm offset. If the offset is somewhere within a close range it should work fine. Are the C55 wheels staggered, though? If so there are some special considerations you need if implementing them on 4-Matic.
