2007 E320 Bluetec Oil Leak
I changed my oil in my Bluetec this past weekend. The car currently has 102,000 miles. New filter, ESP oil, etc. After changing the oil and adjusting the oil level to ensure everything was ok, I did a normal check for leaks around the filler cap, oil filter, drain plug, etc. Everything looked ok.
I drove the car yesterday for approx. 200 miles (work, sons golf match, home, etc). Went to pull the car out of the garage this morning and I was horrified to find oil under the car! I popped the hood to take a really fast look as I was switching everything to the other car. At a fast glance, I see oil on top of the plastic engine cover toward the passenger side and oil appeared to be around the filler capish (technical word) area.
Any initial thoughts of what to look for this evening when I get home? Thank you!
You have hit the nail squarely on the head IMHO.
I find that mine will do the same thing IF the oil fuller cap is not tightened exactly to the correct spot.
Mind you, my car will go 15K miles without needing any additional oil, but it can still
be a little bit messy! I little bit of oil goes a long way in making things messy!
DHG
