E-Class (W211) 2003-2009
Changing water pump questions.
Old Apr 24, 2013 | 02:31 PM
dochou's Avatar
E320
Question Changing water pump questions.
Hello, I'm planning to change my water pump on my E320, standard engine. Not CDI. I have 150,000 on it and the pump failed on me.
My question is which pump do I buy?
When I look up the part on various retail websites such as RockAuto.com, they list 2 different pumps for the same year... one has 2 hose fitting and the other has 3 hose fittings. So I'm not sure which one I need. Any suggestions?
Pumps should come with the gaskets correct? I don't need to buy gaskets separately, correct?
Just wondering what else you all recommend changing out at the same time.
Such as tension pulley, idle pulley, serpentine belt, thermostat, radiator hoses, and MB coolant.
Old Apr 25, 2013 | 12:07 PM
dochou's Avatar
E320
Question
Vin: WDBUF65J55A621979
thanks
anyone have answers to what other things I should replace while replacing water pump?
