Airmatic Lowering at Dealer
I read a previous post made be Stephens that stated:
The car should firstly be driven on to the wheel alignment jig. This is to ensure that it is on a completely flat surface and plugged into the service computer.
Once plugged in, move to Airmatic adjustments.
In this menu option you can raise/lower each of the front wheels individually as well as the rear.
This also shows you the voltage reading of each of the three sensors, along with the tolerance range for each. The idea is to then adjust each to the appropriate reading for the ride height you wish to obtain. (higher voltage = lower) The biggest limitation is the rear as mine is set at the threshhold value of 3.0V, sensor is different, but the tolerance values are on the screen for you to see anyway.
The trick is to get the car to save the values, as once you go to save the changes to 'active" the system asks for a secondary set of inclinometer values. From memory we used 4,-1.3 (I'll double check this at the office today), but had to try three or four different values near the listed range limits to get the system to accept the ride height changes.
This change does not affect the functionality of the suspension in any way, you can still raise and lower the car from the console for example. I have had no rubbing problems which was my biggest concern and believe me, I've done plenty of testing!!
The car now turns in quicker and feels "smaller" on the road. This has also helped reduce lean through faster turns and has not negatively impacted the cars ride.
My question back is how much time do you think it should take the dealer and do you think you got about 2-3" of drop from it? How far can the back be brought down from the ECU?
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Look 6 or 8 threads below....
I'm still hoping we're going to get some answers/opinions about howthis is working out..but no responses to the thread below. Still listening.....
1 Post
Honda Accord EX V6
Originally posted by Dr Chill
Dealer dropped the car 40 mm (1.6") in 45 min. Looks great.
may i know how much do they charge you? the dealer that you talked about is MB Dealer rite?
Porcelain Bus
Currently my dealer is telling me they can drop the front using the ECU about 2-3 inches but to get the car to sit level they would have to do work on the rear outside of the ECU. They are giving me an estimate of 2 hours. About $200 dollars.
I've seen ....
a couple of the cars that ACC did, and the height looked great. And how about that new store they're in? Wow! And I'm not easily impressed....
Yes, your right the new place is really nice. Do you remember how much they charged the other folks for the work? I think I am getting a good deal but that was because of a mix up. Just trying to do a gut check though.
211E55, CLK55(sold), LX470, LS430
fiftyfive, r u going to drop your car? how many inches?
1 Post
Honda Accord EX V6
i did it at topline automobile... they pretty expensive but they really do a nice job!!! I think tbone might know someone who also do it for cheaper yet they still do a nice job
